RCU Forums - View Single Post - Ultimate 42CC Wildthing Conversion
Old 02-06-2017 | 03:39 AM
Larry882
This next group of pictures are all about machining the Tapered bore hub that the trigger magnet is mounted to. For
the guys that have never done anything like this I suggest you get several pieces of 1 1/2" diameter X 7/8" long 6061
aluminum because your going to need them to get the angle set on your compound rest. It's about 10 degrees and
you just need to keep adjusting it until you get it set right.
ID:	2199863   Click image for larger version
ID:	2199864   Click image for larger version
ID:	2199865   Click image for larger version
ID:	2199866   Click image for larger version
ID:	2199867   Click image for larger version
ID:	2199868   Click image for larger version
ID:	2199869   Click image for larger version
