Set the motor with mount and nose ring in place and look atthe clearance between the beam plate and the motor. Pull the motor assembly outand trim the beam plate to assure that when the motor torques it clears thebeam plate. Check and be sure to trim the beam plate at the motor mountattaching points to flush with the motor mount, i.e. don’t leave beam platewhere it can damage the rubber of the motor mount (Hyde YS type) as it moveswhen the motor torques.
Once the trimming is complete, install the motor assembly,prop and spinner and be sure all is aligned properly and satisfactory. Thenmark the locations for the throttle control cable and fuel tubing openings onthe firewall. Remove the motor assembly and drill the appropriate holes for thethrottle control cable and fuel lines.
