RCU Forums - View Single Post - Installing Robart Cub gear
Old 02-17-2017 | 11:06 PM
khodges
Here's a couple of pictures that may help. The mounted gear on this 1/5 scale Sig Cub is a Wallace scale gear, the Robart mounts the same way. I recommend putting a couple of basswood crossmembers inside the fuselage to screw the gear into, it will hold much better than balsa. The picture showing me holding a second set of gear struts is the Wallace gear mounted, and I am holding the Robart gear.
Name:	more scale gear 001.jpg
ID:	2201660   Click image for larger version
Name:	scale gear Cub 003.jpg
ID:	2201661   Click image for larger version
Name:	scale gear Cub 001.jpg
