RCU Forums - View Single Post - Redundant Voltage system
Old 02-21-2017 | 08:59 AM
  #32
FLYERSG
Originally Posted by OhD
High voltage system:
Mezon ESC with BEC set to 8.0 volts to receiver
500 mah 2S LiPo through switch to receiver
Low voltage system:
Mezon ESC with BEC set to 6.2 volts to receiver
500 mAh 2S LiPo through Jaccio Perfect Switch Harness set to 5.7 volts to receiver
The 500 mAh pack is strictly for backup and the RC system is normally operating on the propulsion power pack in both cases. In the case of the HV system the 2S LiPo is being charged by the motor pack. In the LV system you will need to charge the 2S LiPo periodically depending how much time you use it to test and tune with it.
Jim
Just wondering if you're still using this configuration (i.e., using a 2S lipo directly in parallel with the Mezon BEC). In my helicopter fleet, I use Kontronik Kosmik and Jive Pro ESCs which are specifically designed to have a 2S lipo placed in parallel with the BEC output. However, the JETI user's manual for the Mezon ESCs doesn't make mention of using a lipo in parallel with the BEC and I would assume some ESCs could be damaged by using them in that configuration.
Mike
