Redundant Voltage system
Many of the HV servos I use have an input voltage that ranges from 6.0-7.4V. So, you don't have to change out any servos. You just get less torque. On a pattern plane the full voltage and torque from an HV servo is not needed. Trust me.. regulated voltage from a Powerbox switch to an HV servo works great. I have a 2M patternship with that setup.
Ken
Ken
the connector from the esc to the RX , I took a Close look and found all off them bad .
How this happend I dont know maybe they have been like this from the beginning, it has always been a bit to short so I change it and got it a bit longer
#31
So you must have had a short from V+ to GND on the ESC lead to the RX?, causing the RX to shut down/fail safe, leading to a loss in motor control/speed...
#32
High voltage system:
Mezon ESC with BEC set to 8.0 volts to receiver
500 mah 2S LiPo through switch to receiver
Low voltage system:
Mezon ESC with BEC set to 6.2 volts to receiver
500 mAh 2S LiPo through Jaccio Perfect Switch Harness set to 5.7 volts to receiver
The 500 mAh pack is strictly for backup and the RC system is normally operating on the propulsion power pack in both cases. In the case of the HV system the 2S LiPo is being charged by the motor pack. In the LV system you will need to charge the 2S LiPo periodically depending how much time you use it to test and tune with it.
Jim
Low voltage system:
Jim
Mike
