Originally Posted by
Cruiser133
Update, the folks over at the UK forum helped me figure out the recoil issue which was the trip arm on the Tamiya recoil unit was not being properly hit due to the board supplying too much power. The other issue with the motor appears to be a bad board problem. When I pulled the standard board and installed a pro unit, both motors worked fine but it too has the recoil issue. With the American distributor going out of business, where can I send this board to be replaced?
This is Jerry, send me your old board. I'll replace it with another new one. This is the first
instance I've experienced of two bad boards serially ending up with the same customer, I would not have expected that. Both boards I sent you were factory new exactly the way I received them. I may be stopping my business but I'll not ignore this.
Jerry
