Originally Posted by
Captainron2181
Thanks guys! That is good to know,I wasn't sure if I could run with out the liner. That will make this much easier!!
bare in mind if your going to use a larger diameter shaft just make sure theres enough space between the shaft and inner tube for oil or grease to run freely. if its too tight a fit things will get rather warm.
