Thank you Scale you are correct I did miss read this thread as I confused this thread with another elsewhere on the same subject that was confined to just the throttles. I do still recommend either of those two servos for just the throttles on most conceivable twins or multis. The 225's for the larger engines are fine. and have used them no problems on a number of my gassor projects up to 50cc. The HS-85 on the smaller engines are also still my throttle 'go to servo' However the 85 has one drawback and that is it unlike the 225 is a two screw mount instead of a four screw type and that can present a problem if they are mounted sideways. Undesirable servo rocking can occur sometimes in this situation.
Thanks agine Scale
John
