RE: Phoenix Sukhoi & Giles Setup
Pheonix Giles 202 converted to electric. Hacker B50-16L geared 3.5:1 turning a 14*10 APCE prop from 16 Sanyo HR-2600 cells. Radio gear is a JR S-PCM Rx, 2 HS-85's on aileron, 2 HS-5125 digitals on elevator and rudder mounted under the canopy area, Schultze 58bo ESC, 600 mah Rx pack. 7 pounds 9 ounces RTF.
Test flown ysterday, flies fine. Vertical is limited to 100-1500 feet so I need to up the power a bit. Probably try a 15*10 or change the gear ratio slightly. Very nice flying plane...
