Mike, from the look of the damage to the sprockets the case must have been dropped or hit with a heavy force, the must also have had the tracks on as both inner and outer sprockets are bent in the same direction by the same amount, you should also inspect the tracks as I would imagine that the tracks must also have some damage as the sprockets have taken some force/impact to bent in this manner.
