I have used the thixo on every application that I have used the Hysol 9462 on in the past and it has stuck to everything and cured rock solid. You can shorten the drying time by adding a little heat I usually stick one of those clip on drop lights shining on the glue joint and it dries even faster. I also never use the mixing nozzles just spread a bead out on some scrap cardboard and hand mix it. The only negative with this big tube is its hard to just mix up a little dab without wasting some so I keep a tube of hysol 9462 handy for that.
