No problem. Also keep an eye on your gear doors, mine held air fine, but just were not strong enough to hold closed even at 120psi. I run just the lower bypass setup, I replaced them with Ultra Precision 7/16 cylinders. If the doors open in flight and you are haulin, they can tear off.
