RCU Forums - View Single Post - Trainer plane aerobatics
Old 10-27-2003 | 11:53 AM
Montague
Default RE: Trainer plane aerobatics
To answer your question directly, there are some things that an Alpha will just never do very well, if at all. Knife edge and upright snaps and spins are a few.
Moving the CG back and increasing control throws as mentioned above will help you do more with a trainer. When increasing control throws, you can go way beyond the "recommended" throws, just do it a little at a time.
Oh, if you haven't epoxied the wings together, now would be a really good time to do that. Once that's done, you won't have to worry too much about over stressing the airframe. I do inverted spins with my beater trainer all the time. Not quite enough control throws to do a snap though.
That said, I agree with much of the above, learning a lot of acrobatics is best with a more acrobatic plane. The advice to stay on the the trainer for a bit is good for the guys who want to rush on to the next thing before they are really ready for it. That doesn't sound like you in this case.
