Originally Posted by
Verbeelding
Thanks for the info guys...
some pics of VDVmetaal his plane ..
he had just an other question for you guys, the stock rudder system: is it strong enough?
because we read some trouble about it (it is the latest version G2)
thanks again
NO,,,,THE FACTORY INTERNAL SETUP IS STILL NOT UP TO PAR,,EVEN ON THE G2,its still.pretty much the same failure prone setup. You need to place.the rudder servo in the stab and use a rod directly attached to the rudder with a control horn,Its pretty much just a given in these jets to do this modification to prevent rudder flutter.
