Finally got everything on board. With a VT-80 she ends up a tad under 10 kg dry wich is good I think. When attempting balancing as per Daves recommandation I end up rather nose-heavy at 145mm. Looks more like the sweet point will be on the main former (fuselage split). Still very light on the nose-wheel thou. Should I assume everything to be OK then?
