So here is a related question. I'm flying a Galactika which needed a lot of wing incidence to cure a pull to the canopy in vertical up flight. The canalyser is now significantly negative in relation to the wing which I'm sure is giving other issues. I'd like to get it closer incidence wise to the wing but this isn't easy given the mounting method of a dowel at the front into a former and two M3 bolts at the rear.
Given that there is a moulded fairing on the front of the canalyser and the fuz, raising the leading edge by modifying the hole in the former is going to leave a large step between the fairing parts.
Anyone have a clever idea how to accomplish this?
Malcolm
