RCU Forums - View Single Post - Lazy Bee
Thread: Lazy Bee
Old 04-23-2017 | 05:47 AM
Faster Wind's Avatar
Faster Wind
Preliminary gluing is over, now i can assemble the fuselage.
[ATTACH]2211117[/IMG]
[ATTACH]2211118[/IMG]
[ATTACH]2211120[/IMG]
Loop for rudder axis.
[ATTACH]2211122[/IMG]
[ATTACH]2211124[/IMG]
The gluing takes place on a flat table, the fuselage is flat at the bottom.
[ATTACH]2211126[/IMG]
From above also flat only there is a ledge of a loop in a tail, it is necessary to hang from an edge of a table.
[ATTACH]2211128[/IMG]
The nasal part will be clad with balsa 1,5mm.
[ATTACH]2211130[/IMG]
Accidentally broke the part, glued on the glue, nothing terrible.
[ATTACH]2211132[/IMG]
[ATTACH]2211134[/IMG]
The last frame of the fuselage.
[ATTACH]2211136[/IMG]
Pressed the goods to dry out evenly.
[ATTACH]2211139[/IMG]
[ATTACH]2211140[/IMG]
Hinges for the rudder axis direction.
[ATTACH]2211142[/IMG]
ID:	2211117   Click image for larger version
ID:	2211118   Click image for larger version
ID:	2211120   Click image for larger version
ID:	2211122   Click image for larger version
ID:	2211124   Click image for larger version
ID:	2211126   Click image for larger version
ID:	2211128   Click image for larger version
ID:	2211132   Click image for larger version
ID:	2211134   Click image for larger version
ID:	2211136   Click image for larger version
ID:	2211139   Click image for larger version
ID:	2211140   Click image for larger version
