RCU Forums - View Single Post - Lazy Bee
Thread: Lazy Bee
Old 04-24-2017 | 06:29 AM
Faster Wind's Avatar
Faster Wind
Thank you Jester, now it is clear what's the matter.
Assemblage of the wing.
The wall of the spar consists of 3 parts.
[ATTACH]2211505[/IMG]
[ATTACH]2211506[/IMG]
Split the front and rear edges at an angle.
For this, the ends of the edges are machined to the desired angle.
[ATTACH]2211508[/IMG]
[ATTACH]2211510[/IMG]
Back edges for endings.
[ATTACH]2211512[/IMG]
[ATTACH]2211514[/IMG]
Front edges behind the endings.
[ATTACH]2211516[/IMG]
[ATTACH]2211518[/IMG]
The edge for the endings consists of 3 parts.
[ATTACH]2211520[/IMG]
[ATTACH]2211522[/IMG]
[ATTACH]2211524[/IMG]
[ATTACH]2211526[/IMG]
[ATTACH]2211528[/IMG]
The main spar, pine rake 7X3 mm.
[ATTACH]2211530[/IMG]
[ATTACH]2211532[/IMG]
Before inserting the spar, the ribs are put on the side member wall.
[ATTACH]2211534[/IMG]
[ATTACH]2211536[/IMG]
[ATTACH]2211538[/IMG]
At first the central part of the wing is collected, so I did not put on the ribs for the endings.
[ATTACH]2211540[/IMG]
[ATTACH]2211542[/IMG]
Lower spar with allowance for processing.
[ATTACH]2211544[/IMG]
[ATTACH]2211546[/IMG]
Also on the bottom plane are glued three more slats 2,5X3, 5 mm.
[ATTACH]2211548[/IMG]
The upper spar is cut into the size of the root part of the wing.
[ATTACH]2211550[/IMG]
Also on the upper part of the wing are pasted four more slats 2,5X3, 5 mm.
[ATTACH]2211552[/IMG]
Waiting for the glue to dry up depresses...
ID:	2211505   Click image for larger version
ID:	2211506   Click image for larger version
ID:	2211508   Click image for larger version
ID:	2211510   Click image for larger version
ID:	2211512   Click image for larger version
ID:	2211514   Click image for larger version
ID:	2211516   Click image for larger version
ID:	2211520   Click image for larger version
ID:	2211522   Click image for larger version
ID:	2211524   Click image for larger version
ID:	2211526   Click image for larger version
ID:	2211528   Click image for larger version
ID:	2211530   Click image for larger version
ID:	2211532   Click image for larger version
ID:	2211536   Click image for larger version
ID:	2211538   Click image for larger version
ID:	2211540   Click image for larger version
ID:	2211542   Click image for larger version
ID:	2211544   Click image for larger version
ID:	2211546   Click image for larger version
ID:	2211548   Click image for larger version
