RCU Forums - View Single Post - Lazy Bee
Thread: Lazy Bee
Old 04-25-2017 | 09:33 AM
Faster Wind's Avatar
Faster Wind
All slats from the end of the root part are treated level, except for the lower side member, it is processed later.
[ATTACH]2211730[/IMG]
[ATTACH]2211732[/IMG]
[ATTACH]2211734[/IMG]
On the lower rails glued plywood corners.
[ATTACH]2211735[/IMG]
[ATTACH]2211736[/IMG]
On the top slats are also glued corners.
[ATTACH]2211738[/IMG]
[ATTACH]2211740[/IMG]
[ATTACH]2211742[/IMG]
The lower spar is cut to size before the end and one end is bent at an angle.
[ATTACH]2211744[/IMG]
[ATTACH]2211746[/IMG]
[ATTACH]2211748[/IMG]
[ATTACH]2211750[/IMG]
[ATTACH]2211752[/IMG]
Edge for the endings.
[ATTACH]2211754[/IMG]
[ATTACH]2211756[/IMG]
[ATTACH]2211758[/IMG]
[ATTACH]2211760[/IMG]
Lower rails, from the corners to the edge for the endings.
[ATTACH]2211762[/IMG]
[ATTACH]2211764[/IMG]
[ATTACH]2211766[/IMG]
[ATTACH]2211768[/IMG]
Top slats, from corners to ribs.
[ATTACH]2211769[/IMG]
[ATTACH]2211772[/IMG]
[ATTACH]2211774[/IMG]
The lobic on the end is different from the forehead in the root part, it is marked with a small hole.
[ATTACH]2211775[/IMG]
ID:	2211730   Click image for larger version
ID:	2211732   Click image for larger version
ID:	2211734   Click image for larger version
ID:	2211735   Click image for larger version
ID:	2211736   Click image for larger version
ID:	2211738   Click image for larger version
ID:	2211740   Click image for larger version
ID:	2211744   Click image for larger version
ID:	2211746   Click image for larger version
ID:	2211748   Click image for larger version
ID:	2211750   Click image for larger version
ID:	2211752   Click image for larger version
ID:	2211754   Click image for larger version
ID:	2211756   Click image for larger version
ID:	2211760   Click image for larger version
ID:	2211762   Click image for larger version
ID:	2211764   Click image for larger version
ID:	2211766   Click image for larger version
ID:	2211768   Click image for larger version
ID:	2211769   Click image for larger version
ID:	2211772   Click image for larger version
