The final element of the leading edge, 3 mm rails.
[ATTACH]2211878[/IMG]
[ATTACH]2211879[/IMG]
[ATTACH]2211881[/IMG]
[ATTACH]2211882[/IMG]
Tail tail is made of 4mm thick foam.
[ATTACH]2211884[/IMG]
Each element of two plates, the total thickness of 8mm.
[ATTACH]2211886[/IMG]
[ATTACH]2211888[/IMG]
Plywood parts with holes for the axis are pasted into the rudder of the direction.
[ATTACH]2211891[/IMG]
[ATTACH]2211893[/IMG]
On the planking plumage I used a balsa 1,5mm. Thick. For rounded edges, the balsa is cut with fibers across.
[ATTACH]2211895[/IMG]
[ATTACH]2211897[/IMG]
Front and back edges of the stabilizer made of balsa 3mm.
[ATTACH]2211899[/IMG]
[ATTACH]2211901[/IMG]
[ATTACH]2211903[/IMG]
The leading edge of the rudders, balsa 3mm.
[ATTACH]2211905[/IMG]
[ATTACH]2211907[/IMG]
[ATTACH]2211909[/IMG]
[ATTACH]2211911[/IMG]
[ATTACH]2211913[/IMG]
[ATTACH]2211915[/IMG]
