RCU Forums - View Single Post - Airpower EV5U question
Old 05-04-2017 | 05:37 PM
blainer48
My Feedback: (30)
Default Airpower EV5U question
Ok, I have a L-39 with a Airpower EV5U multi function valve and was working fine. My question/problem is I switched from the Spektrum set up to my Futaba and everything works still as far as gear goes up, gear down and the brakes work, but it is the sequencing of the doors that is off now. By that I mean everything opens when it should and closes when it should, but when the gear is up, the inner gear doors and the nose gear door will just open and close on their own. I am on Mode 2 which is what I want but just don't understand why the doors keep open and closing on their own. Not sure if it is a travel setting in the radio or what because this is the first time I have used one of these valves so hoping someone knows the simple answer because I know the valve works. Thanks in advance.
Jason
