Well, just out of being curious, I took the lead for the gear and plugged it back into the spektrum receiver and cycled the gear using the DX18. The gear doors stayed closed when the gear was up like they are suppose to. So, that tells me the unit isn't bad because they stay closed when you run the gear using the "M" button on the unit itself without a transmitter. So, I guess my other question is do I need to reprogram the unit and start over like setting it up from scratch? Does the unit need to be sort of binded to the transmitter that you are using? There is obviously something the valve is seeing in the Futaba that tells it to keep opening and closing the doors when the gear is up. The end points on the DX18 are 100 both ways and its the same on the Futaba.
Jason
