Originally Posted by
TheBennyB
Right on, yea a bit pricey but usually the bigger the toy the bigger the cost. Really you could also probably use the 12V version of the TARR2.
I wonder if I could use a 12 volt TARR as a basis for an acoustic smoker? I'd really like to get great sound in this, so it seems a perfect way to go. The exhaust system is all metal and the muffler should provide a great holding chamber so a system that lets you rev the engine would give a great effect.
I'm hoping I'll be able to run this on 3S lipo batts. The instructions ask for two sealed lead acid 12 volt batts connected in parallel. But, it's an old kit and battery tech has advanced quite a bit.
