RCU Forums - View Single Post - Phoenix Models 1/4 scale Lysander
Old 05-12-2017 | 04:38 AM
Wile E's Avatar
Wile E
Firewall pre-drilled bolt holes were filled with dowels. New mounting points for the G-62 were drawn and drilled. A 1/8" aluminum backing plate was constructed for the back side of the firewall to spread the load of the through bolts (all will be thoroughly epoxied and braced on the inside, also). Engine was bolted up to the firewall and the cowling slid into place. TADA! Engine fits inside cowling, may need a bump for the spark plug cap. Specs for a custom Bisson wraparound muffler have been sent for a quote, the mod would raise the assembly to almost level for inside cowl clearance.
ID:	2214627   Click image for larger version
ID:	2214628   Click image for larger version
ID:	2214629   Click image for larger version
ID:	2214630   Click image for larger version
Name:	motor mount backing plate.JPG
