RCU Forums - View Single Post - Phoenix Models 1/4 scale Lysander
Old 05-14-2017 | 02:48 PM
Wile E's Avatar
Wile E
G-62 engine fitment:
Using the Toni Clark cast aluminum 90 degree bend carb adapter: https://www.aeroscale.shop/collectio...um-intake-bend
and 7 mm thermal block : https://www.aeroscale.shop/collectio.../thermal-block as a spacer along with the regular carb block,
and an 18 mm intake tube:https://www.aeroscale.shop/collectio...nt=40161414791 from Vogelsang Aeroscale, plus some fine work with a Dremel tool, the carb lays nicely along the motor box. A choke rod will come out of the cowl ring and be hidden by the cowl flaps. An ignition kill switch will also be hidden in the cowl flap opening.
ID:	2215217   Click image for larger version
