As confusing as it may sound. It DOES NOT tell you where the CG is. It ballanced the plane to the cg that you tell it to. You have to know before hand where the CG is. If you tell the wizard your cg is on the nose of the plane. The wizard will tell you the CG is on the nose of the plane. So.... You have to get the CG from your manual or from someone who knows where it is. Once you know where the CG is and put the correct info into the wizard the wizard will tell you were the CUTRENT / WRONG cg is. Then you add/ move/ or subtract weight untill the wizard cg is correct with what the "Target cg" should be. I could be saying it wrong. So the CG wizard....is the Ballance wizard ...lol
