I just balanced my Comparf Mig15
I put it on the scales, the rear sensors were 600mm from the front sensor. The weight was 12800g. The balance point was 49mm according to the app. My target distance is 120mm. This is from the rear of sensor to the correct cog which is 50mm forward of rear wing tube. I need to add nose weight.
Worked well.
