Maybe to help understandig what CGWizard shows on the screen, let me tell some words:
The value shown as "Balance point" is the
current position of the "Center Of Gravity".
This doesn't means that is the good location of the CG. The rigth place of the CG is where you marked on the very first step of the balancing procedure.
And this mark must be set as per the manufacturer reccomendations.
Then, adding or removing weight, you need to match the "Balance Point" with the CG.
That's why I didn't wanted to name this value as "Center of Gravity", otherwise people may get confused.
May I suggest you to watch the video I made to explain this (excuse me because of my poor english):
Versions in spanish and franch are available as well
In the
CG Wizard manual there are some pictures that may also clarify how this works
Nevertheless, all your comments or remarks are welcome, and this lets us enhance the product. We will compile and consider your suggestions in order to include them on next releases of the software, the hardware and the documentation as well.
Thanks again!
Daniel
