IF its IFA not a big deal, but if its is not IFA its not mounted on the top center-ish like it should be. It doesn't have anything to do with the over all height, but the amount of tank blocking it from the front. If your even slightly higher than the person shooting at you your blocking it, whereas the JT posted in one of your video's from the Danville event its on the top and it would have to be a lot higher than the opponent to do the same thing.
