Originally Posted by
skymaster68
is it possible to use telemetry on a dual turbine setting using an 18MZ? will there be 2 screens with the info??
To be specific in answering your question, you will need to give more information regarding your setup. Which telemetry adapter are you going to use? Which ECU's are you going to use? The telemetry options on the 18MZ are covered very well in it's manual, but basically it will depend on what sensors you allocate to the available slots and how you want to display the telemetry. The 18MZ has certain limitations, but many guys are using it, with telemetry and twin turbine installations.
Cheers,
Jan
