Telemetry?
#126
#127
Leon
RCG has a big Jeti thread on the radio section, post your question there as it is supported by Esprit, Jeti USA.
https://www.rcgroups.com/jeti-usa-794/
Good luck.
Good luck.
#130
My Feedback: (7)
As for an issue such as defective throttle cable, such things are pretty easy to detect during maintenance and don't generally develop unless the cable didn't have proper strain relief, etc. Also, if the intermittent connection is the signal lead you could still have a flame out (throttle signal out of bounds) without ever having an issue with the power or ground pins so an extra connection wouldn't help in that regard. As I see it, if you can't trust your basic electrical connections in the aircraft then it basically isn't safe to fly as such an issue can develop with any cable in the plane and most of them could cause far worse than a flame out.
#131
My Feedback: (53)
Wayne, I also don’t see any advantage....since you still have only one Signal input.....and I agree if it’s intermittent then fix it....don’t rubber band it. On the KingTech the ECU is actually power by the RX, the ECU battery is only for the Starter, glow and the fuel pump....
#132
Can someone please explain why there is any benefit to this ? The ECU has it's own battery. The ONLY power related issue with the CB200 is the fact that you must never draw more than a couple hundred ma from RX1 or RX2 which is why devices like the Cortex Pro (which actually connect to RX1/Rx2) recommend an additional power connection. There is no such restriction on any off the the other ports. I see no benefit or harm to having a secondary connection to the ECU but is don't believe there is anything related to the Jeti central box that makes such a connection necessary.
thanks for your clear explanation. I think this idea has done the rounds for a while now.
cheers,
Leon
#133
My Feedback: (7)
Also, in the case of the Jeti Central Box, there is no difference than a regular receiver in this regard as the only ports that have power restrictions (receiver only/no servos) are the Rx1 / Rx2 ports and these aren't involved with the ECU in any way. I got the impression that since there is a recommendation to run extra power to devices such as the Cortex Pro, which actually draw powered from Rx1/Rx2, that people were assuming that you needed to do so to any external device connected to a Central Box and that simply isn't true..
#134
My Feedback: (53)
You're correct and thanks for pointing that out. That part of my post was poorly worded. I was really trying to say that powering things like the pump/starter, things that use significant power, already have a dedicated ECU battery and they don't place any additional load on the receivers throttle channel. The actual ECU's power requirements from the receiver itself are pretty minimal. Certainly nothing that requires an extra power connection to share the load with.
#135
Why not have a power backup? Will it hurt anything....no...will it possibly prevent a flame out due to a power issue....yes....
I can only suggest tricks...cant persuade people to use them.....
#136
#137
My Feedback: (7)
Your extra cable will prevent power loss but it won't prevent loss of throttle signal. If you lose your throttle signal but not ECU power the ECU will STILL shutdown the turbine as it will think it's lost RC. If the throttle signal either non existent or out of bounds the result is LOST_RC fail safe shut down.
#138
My Feedback: (53)
Using your logic, perhaps you should also double all the servo power? So everything except perhaps telemetry’s........
AND I don’t actually disagree with you...but like I said before feel free to do what you wish, but that doesn’t mean I have to follow suit......maybe your friend should have used a different Servo Clip......But I for one don’t see any advantage....that’s all I said. Case closed!
