RCU Forums - View Single Post - Need help troubleshooting Intairco UAT
Old 05-31-2017 | 05:43 PM
rjpmodel
There are a number of sources for air leaks in a jet installation and my problem was air leaking through the fittings using the supplied rubber washers. I don't believe my leak problem was great enough to fill half the tank with air during a normal flight time. If the air trap is half empty after a flight, there may be a larger air leak coming from another source.
