RCU Forums - View Single Post - Prop Nut
Thread: Prop Nut
Old 06-09-2017 | 11:57 AM
jc03
Originally Posted by danielplace
Just lube it up. They usually don't go on that tight just a little snug unless the shaft wasn't properly threaded which I have seen many times. You hold the prop with thick towel and tighten with a nut driver usually but any means will get it on wrench, socket and ratchet but do not us any power tool as it may gall it or spin the prop and cut you badly. Only make contact with the nut to the prop and don't tighten it hard against the prop or you will jam the drive dog forward and loose your gap and ruin it.
Did you put a decent flat spot for the set screw on the shaft and grind the end of the setscrew flat before tightening it in with liberal coat of red locktite ?
Thanks for the reply. I didn't think of that. You mean put the prop slots into the drive dog and hold the prop so nothing spins, right?
I didn't grind a flat spot. Good thing I didn't get everything set. Haha! I'll dremel a decent spot before getting it together. Thanks!
