RCGF 35CC spark plug boot issues
Hi everyone, I am having some difficulty with my new Great Planes Escapade 30cc ARF kit specifically to do with the engine. I bought a 35cc RCGF with the rear exhaust and carb and I'm having some issues with the spark plug boot. I have mounted the engine and the ignition as well as setup the throttle linkage and choke. The problem is the plug boot doesn't seem to be mounted snug enough. I have not run the engine yet but I have no doubt that the vibration alone will vibrate it right off. It is definitely seated all the way but I know that it will not stay on. Also since it is mounted with spark plug pointed down, gravity is also working against me. I have looked on the Web on several different sites and have not yet seen a good fix to my issue. I have found one link that suggests I should modify the casing and put a screw clamp on it but I rather not have to cut up my new setup. I am hoping that someone has a better idea for me or at least tell me that the fix that I described above is the only good solution so I can feel a more comfortable doing it. Any suggestions would be greatly appreciated. Also real quick, for a plane of this size (80 inch w.s.) and for someone who is not the greatest flyer, should I go with flaps or no flaps?
FYI, This is my first giant scale rc airplane and I want to make sure that I have the best possible setup for the plane and for my flying skills which are mediocre. So here is my setup, if there is anything that you think I can improve on or just change completely please feel free to let me know. I have not installed any of the servos, receiver, batteries or gas tank yet specifically because I wanted to hear from some seasoned flyers first. This is not like my other cheaper planes or my other rc cars and trucks. If I screw up it's going to very expensive. Your suggestions would be much appreciated.
Great Planes Escapade MX 30cc
FrSky Taranis X9D Plus transmitter
FrSky X8R receiver
(8) Tactic TSX55 servos
(1) Rcexl Opto Gas Engine Kill Switch
(1) Tenergy NiMH 6v 2000 mAh battery for receiver
(1) Tenergy NiMH 4.8v 2000 mAh battery for ignition
(1) Xoar 19x8 wood propeller
(1) Eagle A3 Super II 6-Axis Gyro w/ programmer
(2) DU-BRO Switch w/ charging port
Thanks for your help
