RCU Forums - View Single Post - Zenoah G45 Conversion to Electronic Ignition
Old 06-25-2017 | 09:43 PM
Truckracer
My Feedback: (19)
Dan, there are a number of companies who supply ignition kits for the Zenoah engines. Have you looked at the ones supplied by RC Extreme Power. In many cases, the sensor is mounted in a fixed position that usually produces a timing in the normal range. If adjustable, set to the same 28 degrees you are use to with the Brison and most engines.
