Originally Posted by
i3dm
For those interested:
I have developed a pulsing smoke controller which will be ready very soon. It will work with any radio and it will be inline between your pump controller and your RX on your PWM line and will have variable rates of pulsing smoke for any radio.
Rates are controlled by your Tx End points for that channel.
I use Powerbox smoke pumps and there is no separate controller. The pump has two leads - one from the battery and one directly from the Rx. Therefor I can only manipulate the radio signal or the power supply to the pump. Will it be possible to use your controller with the Powerbox smoke pump?
Cheers,
Jan
