Just a quick note.
You have to make up a Y harness to get full telemetry from your royal srs. There is only one 4 pin spectrum port on the royal and KT . So make a Y harness and plug it into the tm1000. .from there plug your KT cable into it for the turbine. Other end you use a normal spektrum cabe to the royal
Make sense?
You have to make this Y harness...spektrum does not sell this.
I did see one on ebay some other company was making. If you buy one make sure it's the 4 pin NOT 3 pin telemetry cable
