Use a volt meter to read voltage on the pins of the smoke unit plug on the IBU.
if no voltage presnet, then follow,the manual to move the stick to activate the smoke unit, hold stick for a few secons similar to start tank. Then measure voltage again.
Compare voltage reading with rating on aftermarket smoke unit.
also, aftermarktet smoke unit might draw more current than IBU is rated for, just a possibility.
