Well on this toy store variety stuff they generally do not care or bother with product support. It appears that the prop saver hub is pressed onto the shaft. If the proper part is truly avalible then order it. If you actually get one then its a simple matter to inspect it for the method of installation. likely you can just clamp on to the old broken part to pull it off or failing that just, grind it off..
John
