If you're running it on straight battery voltage and it won't make smoke you need to contact the place you bought it from to get a replacement. Otherwise your only choice is to take it apart and see if the resistor (heating element) needs to be replaced or if there are any loose wires. This is one more reason I stick to the stock smokers, at ten bucks each I can afford to just swap out the bad ones.
