Hi Mike,
I must apologize. I built the Flash (which is the 45 sized version) and not the Flash S which is the smallest version. I've also built 3 Flash RS (.60) size. If you cannot locate plans for the Flash S, I would be happy to send you scanned plans from the slightly larger Flash. Not ideal, but very helpful when building. You could build the kit without plans (easy for me to say, having built several) just using the interlocking feature of the design. It is nice to know where some of the odd bits go! And plans sure help.
regards,
Will
