Originally Posted by
Snake Bite
Has anyone tried to use the Kingtech KT Telemetry module with Spectrum DX18 radio? I purchased the unit to use instead of the GSU on start up. I have a three sheet instruction and I have followed it to the letter, however, I have not been able to get the unit to work. I am using a DX18 transmitter/ Powerbox Royal SRS w/ DSMX satellites/ Spektrum TM1000 telemetry module/ and the Kingtech K-180G turbine and ECU. All of this is less than a month old. I can connect the telemetry module to other receivers, how ever, when trying to add the Kingtech telemetry module, no data is transmitted from the Kingtech telemetry module.
If any one out there can lend a hand, I would greatly appreciate it. My first jet should be delivered in a week or two, and I would like to install this in this jet.
Thanks for any assistance!
Jake
You MUST use the telemetry cable that came with the adapter if it is a new KingTech GSU!!!
