I have a new evolution 10cc gas engine. I have a separate battery for the electric ignition. I also have a on off switch and a kill switch from Evo. I have the battery hooked up to the on off switch. Then to the in on the kill switch. Which goes to the receiver and then to the electronic ignition and then to the motor. The problem is I can't get the Motor to start. I have spark and I'm using a cordless drill that I moded to get the motor to turn over. Sometimes it will
Pop as if it will start but it doesn't. I called horrizon email times but have had no luck. I also have the needles to factory settings. Please help I'm lost at this point thanks Kevin
