RCU Forums - View Single Post - Spektrum DX6 use of flaps and mix elevator
Old 08-20-2017 | 04:16 PM
petrolia
Default Dx6
Thanks for your email. Yes this is the bixler 2 from Hobby King with Flaps. All that was necessary was to install the two additional
servos required and the ESC. At the moment I have it set up with y adapter in channel 5 and aux 1 which works fine. I would prefer
to continue with this setup rather than changing to flaperons. Would prefer a bit of down elevator if you can walk me through. As
indicated earlier, I am using switch B.
Thanks again stuntman.
Louis
