Hi Louis,
Step by step ; 1) Hold scroll down, turn on transmitter
2) scroll down to system setup tap scroll
3) scroll down to aircraft type, tap scroll scroll down to flap tap scroll . On page 13 of manual
4) tap back button to get to system setup tap scroll to get channel assign. Assign the flaps to the channels you have them plugged into. On Page 16 in manual
5) hit back button 3 or 4 times to get out. of this menu
6) on main page you should see flap option scroll down to that tap scroll to get into flap menu on page 35 of manual
7) scroll down to switch, tap scroll to highlight flip switch you want to assign to flap tap scroll to get out now scroll up to position 0 tap scroll you can now program flap. tap scroll now you can program elevator
8) tap scroll flip switch to other position you should be in pos 1 tap scroll to highlight flap change setting tap scroll highlight elevator, change setting there
hope it works P>S> when you tap scroll you are going into enter Alan
