RCU Forums - View Single Post - AMA Statement - Didn't even MENTION John Taylor!
Old 08-21-2017 | 04:46 PM
  #67
franklin_m's Avatar
franklin_m
Originally Posted by mr_matt
how do you get a turbine waiver without joining? CBO programming requires passing a test. what about getting a LMA "permit". CBO programming requires a signed off inspection
You're right, if you want to fly turbines or sUAS greater than 55lbs, AMA has you by the throat. The former because the safety code says you'd follow the turbine rules, and the latter because the law requires CBO inspection if over 55lbs.
But if you're content with EDFs (which perform quite well) and don't have a need to fly >55lbs, you don't have to be a member.
