RCU Forums - View Single Post - Firewall Hole
Thread: Firewall Hole
Old 09-02-2017 | 10:21 AM
onyta
To flyboy2610 & sticKSLAMMER THANKS U MUCH .....THE SBACH'S TANK IS SEVERAL INCHES FROM THE FIREWALL & THE FUEL LINES ROUTE INTO THE
SIDES NOT INTO THE CENTER(MIDDLE) , BUT THEY COULD............SOMETIMES WHEN U HAVE A MOMENT???????TAKE THE AIR CLEANER FROM YO WEED-
EATER & CRANK & RUN @ FULL WIDE OPEN PEDAL-TO-THE-METAL AND WATCH THE FUEL "FROTHING" FROM THE MOUTH OF THE CARB. THIS IS THE
STUF THAT GETS INTO YO PLANE.
UNLESS SOMEONE KNOWS BETTER I WOULD RECOMEND THAT THIS 'HOLE' ALWAYS BE PLUGED,STOPED-UP, JUST BE CAREFUL BECAUSE ANYTHING
LIKE A SMALL PARTICLE OF WOOD OR WHATEVER YOU PLUG THE HOLE WITH WOULD GO RIGHT INTO THE CARB. IF GIVEN A CHANCE......
IN BUILDING MY G.P. ESCAPADE 30CC I PUT A PIECE OF NYLON SCREEN OVER THE HOLE......REASON BEING, ANY
FORGOTTEN SERVO SCREW(FOR EXAMPLE) LOOSE IN THE INSIDE OF THE FUSE. DIVE THE PLANE AND IT COULD AND WOULD GO INTO THE CARB. & MAYBE GET PAST THE BUTTERFLY
AND FIND THE TOP OF THE PISTON @ 8K RPM. BET THIS HAS HAPPENED TO SOMEONE OUT THERE & THEY NEVER KNEW WHAT BLEW THE ENGINE.
Thanks again from DOORGUNNER1stAIRCAV
