Originally Posted by
VK96
NWS is a dedicated channel and not run through the cortex. I've not tried reducing the gyro gain back to zero, but can the next time it happens. The issue is random...just begins right after powering up. Could go 20 power cycles with no issues and then all the sudden it'll occur. Just curious, have you been able to run EX Bus to the GS200? Found it odd that both controllers responded the same way in that configuration.
I had several GS-200 controllers and now the newer model with the black casing, but never tried the bus setup. I would try to reduce the gyro gain to zero on the nose wheel to see if it's the gyro function or something else.
Thomas
