RCU Forums - View Single Post - Multi engine speed controls - fixed wing or copter - how do you control them?
Old 09-19-2017 | 02:10 PM
BarracudaHockey's Avatar
BarracudaHockey
Depending on the radio you can run a twin on something like a Dx-18 with special programming for multi engines by plugging each ESC into its own channel.
If you're using one of the onboard BEC's you have to pull the red wire from the other one. You can also just program them individually and then connect them to a y harness.
