RCU Forums - View Single Post - JR28X Jet Programming
Old 09-29-2017 | 07:14 AM
F4dar
My Feedback: (55)
Default JR28X Jet Programming
Hey Guys,
Just upgraded to 28X from my 12X and trying to figure out how to setup my Flash (12 ch w/smoke), F4 (12 ch w/out smoke) like to add few additional functions in future. I have some basic questions per below, but more in depth help on setup. Looking for JR team pilot for guidance, if you are available, please pm me? thanks Jason
I am going to setup both jets with Power Center Hub/xbus connected to RG812BX RX, Powered Servo Converters for main flight surfaces, regular converters for other channels. (All PWM servos for now)
Basic Flight mode setup (3 modes) to include all dual rate/exp/trims
My Basic questions:
-If i activate Xbus in radio and Rx, can i still use throttle ch from PWM output on RX?
- How do you setup Throttle trim for jet (make it act like a slider) or some clever alternative? In addition the throttle trim goes in both +/- direction, confusing?
- Cannot figure out how to assign group trim to surfaces for each flight mode, the switch logic confusing me?
- There is servo speed, and delay for almost every transition/mode switching, Not sure which has priority, do I need to program in flap servo speed or i can just do delay, does it matter?
- Same questions for servo travel, dual rates, sub trim. I can limit servo travel in several different places? does it matter where you set it and what is the priority?
- I really need a simple explanation of how to assign 3position switches (logic).
I could also use the help if someone can basically list their setup on comp arf flash.
Tx for your help.
Jason
